August 25, 201510 yr The engineers at work decided to use A514 grade E and grade H on one of our projects, the main plate is 3" and the lifting eyes are 1.75". This isn't a steel that I'm familiar with and the engineer sent me two pages out of a 20 page article about fabrication with QT steels. Primarily we use A36, 50K, 1018, 4140, 4130. This project will be picking up a lot of weight and I want to be certain that I am doing my part properly. Is there any info you guys can give or point me in the right direction. The research I have already done hasn't said much about the welding side of it ( preheat, post heat, interpass heat ). I have already found the right wire to meet the specs but I still want to learn more before the job comes up.
August 26, 201510 yr Author all I ever get from the engineer is uh uh uh uh and no real answers. I found an article on the fabricator that helped but I would still like to learn from others experience.
August 26, 201510 yr The manufacturer of the steel may have a fact sheet on it containing info on how to work it.
August 28, 201510 yr My cheat sheets for Bisplate (the Australian equivalent to A514 most grades) tell me it is a minimum preheat of 140 C (285 F) for a joint with a combined thickness measurement of over 100mm plus 25 C (77 F ) for a rigid joint or high humidity conditions.Max interpass is 220 C (430 F)heat input 1.5 - 5.0 kJ/mm (37 - 123.5 kJ/in) That last number seems a little high to me but it has been a while since I have welded anything that size.P.S. it is my favorite stuff, it is staggering how much punishment it will take without fracturing. Edited August 28, 201510 yr by yahoo2
August 29, 201510 yr the following link seems to agree with Yahoo2Making the Choice: Filler MetalsWelding A514 is not complicated when some precautions, especially with filler metal choices, are used.A primary concern is filler metal hydrogen content. You should not use filler metals that deposit weld metal with diffusible hydrogen content greater than 8 ml per 100 grams of deposited weld metal. A514 is sensitive to diffusible hydrogen, which may result in hydrogen cracking.Figure 1Filler Metal SelectionASTM A514 and A514M-05 up to 21/2 Inches ThickWelding ProcessAWS A5 SpecificationClassificationSMAWA5.5/A5.5M-2005E11018M or E12018MGMAWA5.28/A5.28M-2005Solid electrodes ER 110S-1 andER120S-1 orMetal-cored electrodes E110C-K3,E110C-K4, and E120C-K4FCAWA5.29/A5.29M-2005E11XT1-K3C and -K3ME11XT5-K3C and -K3ME11XT5-K4C and -K4ME12XT5-K4C and -K4MSAWA5.23/A5.23M-1997Solid electrode/flux combinationF11AX-EXXX-XXX and F12AX-EXXX-XXXor Composite electrode/fluxcombination F11AX-ECXXX-XXX andF12AX-ECXXX-XXXThe filler metal strength depends on the application of the A514.Figure 1shows filler metals you can use to match the strength of base materials up to 21⁄2 in. thick where the same mechanical properties as the base material are required. On base material thicknesses greater than 21⁄2 in., you can use the same filler metals, but their strength exceeds that of the base metal, a condition called overmatching strength (see Figure 2).Figure 2Filler Metal SelectionASTM A514 and A514M-05 Greater Than 21/2 Inches ThickWelding ProcessAWS A5 SpecificationClassificationSMAWA5.5/A5.5M-2005E10018MGMAWA5.28/A5.28M-2005Solid electrodes ER 100S-1 orMetal-cored electrodes E100C-K3FCAWA5.29/A5.29M-2005FCAW A5.29/A5.29M-2005 E10XT1-K3C and -K3ME10XT5-K3C and -K3ME10XT1-K7C and -K7ME10XT1-K9C and -K9MSAWA5.23/A5.23M-1997Solid electrode/flux combinationF10AX-EXXX-XXX or Compositeelectrode/flux combinationF10AX-ECXXX-XXXWhen joining A514 to other low-alloy steels or carbon steels of lower strength, use a filler metal with strength that meets the lower-strength base material's properties. For example, when welding ASTM A36 to A514, use a 70-KSI-tensile-strength electrode to match the lower-strength material. Don't focus solely on strength; keep the hydrogen cracking risk in mind.Heat Input ControlEven though A514 is readily weldable, excessive preheat and interpass temperatures and welding heat input can affect the alloy's chemical properties.Figure 3lists typical preheat and interpass temperatures for A514. These temperatures apply whether you are welding A514 to itself or to other, lower-strength materials.Figure 3Although welding A514 is not difficult, joining it successfully requires close attention to the preheat and interpass temperatures.Thickness (In.)Minimum Preheat andInterpass Temperature (F)Maximum Preheat andInterpass Temperature (F)Up to 3⁄4504003⁄4 – 11⁄212511⁄2 – 21⁄2175400More than 21⁄2225 It should be noted that preheat and interpass temperatures higher than those shown in Figure 3 may alter the mechanical properties of the material. Tempil® Sticks, contact pyrometers, infrared thermometers, or other heat-measuring devices should be used to control preheat and interpass temperatures.In addition to the preheat and interpass temperature controls, heat input, which is a function of amperage, voltage, and travel speed, must be restricted. Heat input is expressed in joules per inch. The formula is:Heat Input (joules/in.) = (Amperage X Voltage X 60) ÷ Travel Speed (IPM)Typical heat input is about 55,000 joules per in. (±20 percent). For other heat inputs, it is advisable to contact the steel manufacturer for recommendations.As a final precaution, A514 is not intended to be used in the postweld heat-treated (PWHT) condition, as it will alter the mechanical properties for which the material was intended.Other sources of information for welding A514/A514M-05 steel are the steel manufacturers' fabrication guides and:AWS D1.1, Structural Code—SteelD14.3, Specification for WeldingEarthmoving, Construction, andAgricultural Equipment
August 31, 201510 yr Author I'm always hesitant about working on things I have never done, I don't like not being informed or trusting only the engineers word. Thank you everyone for replying, I appreciate the help gentlemen.
