December 10, 200718 yr My buddy had this follow him home also. Any info, pictures, etc would be appreciated. Di Acro Precision Machines Oneil-Irwin Manufacturing Company Minneapolis Minnesota Bender#2 L1091 We're sure there are lots of parts missing, just don't know what they are. Thanks bruce
December 10, 200718 yr Author Thanks Glenn. If I'd had half a brain engaged this morning, the search engine woulda come to mind. (BOG)
December 11, 200718 yr Di Acro used to be on my way to work here in Canton Ohio until about a year and a half ago when it was sold. I stopped in a few dozen times and had some looks. The company that had the Di Acro line did my powdercoating for my wrought iron projects...Bob
December 31, 200718 yr ask and ye shall recieve recently snagged off ebay as I thought I might want to build something similar (edit > DOH got a repeat attachment and cant seem to edit it out)
December 31, 200718 yr If you are going to build a bender build this one instead. Bender Similar to the Hossfeld #2 You can do so much more with it than the DiAcro ever did. Plus there is far less machining involved and less steel plates...BobDi-Acro Manual and Power Operated Machines For Precision Metal Forming LINK
January 1, 200818 yr Search youtube for Tom Bland (iron bugs, video one). This is about a nine minute video of him using his di-acro bender. Looks easy. I don't know how well the unit would hold up to hot bending but it sure looks fun to use on the cold stuff.
