The wait is on!
mage2
So I have built the forge. well mostly. I am using 2" wool sourced locally and applied the ITC-100, drying time.. two days!! in texas?.. i have my doubts in that. The way the weather is going round these part, it might fire its self.
So it dried for a few days in the Texas heat/sun.
I put the burner in place and started using it.
Specs:
The pipe is 8" long. I am using 3/4 pipe, 3/4 T connector and a .35 mig tip.  The inside of the forge is around 200-250 ish cubic inches.
I have been running at around 5 - 7 PSI but can go much higher. I have formed a cone out of the wool where the burner enters the chamber.
Its 2" ceramic wool with a ITC-100 coating and a solid firebrick (also ITC-100 coated) that I can replace easily.
Here are some pictures.
Any input on tuning the burner would be great.
the blue hue'ed pictures are right at startup
the red/orange is after its been running for a few minutes.
forge_3.thumb.jpg.dbfb7f45bad11d6161de9eforge_2.thumb.jpg.61de3a69581d72939d7a27forge_1.thumb.jpg.98d86ee2583b7d396844f0
Thanks for tipping me you have it running I don't know why it didn't show up or maybe I just missed it.
Anyway what questions do you have about tuning it? It's hard to tell what shade blue the flame is on start up. Taking a couple minutes to warm up and stabilize completely is pretty normal.
How hot does it get after 15-20 minutes? The hard brick floor will suck up some heat till it warms up. Is that a split brick floor? If it's a full brick it's going to really suck up heat and fuel. I use split brick on kaowool or insulating castable refractory.
Once it's up to temp shoot a pic sideways across the door so we can see what color the dragon's breath is once it's HOT.
