June 11, 201510 yr hello, complete newbie, dont know squat. so be nice,,,no biting the newbie!!!!! going to make a forge, have been looking for a blower,,did not want to go the hair blower route, i came across a hvac, gas flue exhaust blower... any comments as to if this idea is ok or just plans insane? i figure about 5' of duct reduced to 2'' at the pit Edited June 11, 201510 yr by frodo
June 11, 201510 yr Is this the forge or are you thinking about converting it? Didn't you just post a bunch of these individually from your gallery section?Posting them all in one message is a lot more convenient to folk viewing them than individual links to the gallery.We'll need to know more about what you have in mind for a forge and what fuel you want to use. The size of forging you'd like to do makes a difference too.Frosty The Lucky.
June 11, 201510 yr That looks more like a rocket stove than a forge. Edited June 11, 201510 yr by HWooldridge
June 12, 201510 yr Author HWooldridge, it is a rocket stove, i was in chat, and could not figure out how to post a picture their..i posted it heremakes an excellent squirrel stew, Frosty, I have an old grill, on a stand, nothing special, i figure for my first, that should be good enough. will be doing small work, RR spike knives and suchprobley use charcoal for fuel, i have a gas toy already, LOL do not need another Edited June 12, 201510 yr by frodo
June 12, 201510 yr Many folks swear by the HVAC flue exast fans. They are reliable, provide good air and dont mind heat. Take a look at the solid fuel section, lots of posts describing side blast and bottom blast forges. I recoment looking very hard at the "55" forge, particularly the simple and side blast versians. Many peaple do fine work with brake drum and brake rotor forges but I find them to be more work and expence to build. Many have built their own firepots with great success for bottom blast forges and side blast are as easy if not more so. One particular nice setup using plumbing parts (as many brake drum forges do) is to use a 6 or 8" to two inch reducer for a fire pot, a peic of 1/2 bent into a "S" makes a fine grate. Don't fall in to the trap of building to much forge at first and use some king of air controll to conserve fuel, keep from cooling the fire, keep the fire from becoming oxidizing and to keep from blowing fuel out of the pot
June 13, 201510 yr Author thanks for the tip, i looked at the 55 and like the chimney, like the simplicity
