rider666 Posted February 24, 2015 Share Posted February 24, 2015 Hello!I need some help. i am building square fire pit the top dimensions are 1x1m and at the bottom is 40x40 cm. it will be made out of steel plate of an old diesel tank. the plate is 4mm thick. Is that enough for the fire pit?thank you! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 24, 2015 Share Posted February 24, 2015 What will you be burning? How often? How long? Will it be rained on? will you have drains in it? Quote Link to comment Share on other sites More sharing options...
rider666 Posted February 24, 2015 Author Share Posted February 24, 2015 It will have drains, it will be raining on it. It will be burning wood like pine etc. i am building it for one irish pub for the outside so it will be burning quite alot. but only for 2-3 months per year, and maybe 2-3times a weak. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 24, 2015 Share Posted February 24, 2015 in plain steel it will rust out over time as water and ashes are a corrosive mixture. Quote Link to comment Share on other sites More sharing options...
rider666 Posted February 24, 2015 Author Share Posted February 24, 2015 will it last 3 seasons? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 24, 2015 Share Posted February 24, 2015 Depends. I made a firebox for a Renaissance Ship replica out of 9.5 mm steel and it lasted in a wet environment more than 3 years but less than 10; low usage but poor care taken of it. Quote Link to comment Share on other sites More sharing options...
rider666 Posted February 24, 2015 Author Share Posted February 24, 2015 (edited) thank you. I think i will put schamott bricks inside the fire pit it will last longer i think? Edited February 24, 2015 by rider666 Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 24, 2015 Share Posted February 24, 2015 If they don't trap water/ash against the metal Quote Link to comment Share on other sites More sharing options...
njanvilman Posted February 28, 2015 Share Posted February 28, 2015 You might have more of a problem with the metal warping from the heat. Since you are repurposing old steel, just build it and see what happens. Consider it a learning curve...if it works for three years, great. If not, you will know what to do different for the replacement. Quote Link to comment Share on other sites More sharing options...
natkova Posted February 28, 2015 Share Posted February 28, 2015 What are you using for air suply. Quote Link to comment Share on other sites More sharing options...
