October 18, 201411 yr Sending more photos. The venue is Flowering Mountain, a 'sort-of school' 6 miles south of Ojo Caliente, New Mexico, USA. The teacher, Martin Prechtel, is an artist among other things, and he drew in outline his version of a Sythian deer head with the scrolly horns, seen as a big finial atop the large thumb latch and as large hinge finials. We had them water-jet cut and arc welded them to the strap; then disguised the weld. The rest of the design work he left up to me and my helper, a rare treat and a pleasure.
October 30, 201411 yr Beautiful work! In the third picture, there is a piece with a hole in the diagonal that is just too perfectly done. How did you get that to come out so nicely on the end of the bar like that? I tried playing around with it tonight in some 5/8 square, and failed miserably. I love the way it looks.
October 31, 201411 yr Author DanBrassaw, Winslow Morgan, now working in Pennsylvania, made the cane bolt finial. It was in my saved junk pile, and I lap welded it to the 1/2" stock. I don't know how he did it, but I went to the shop this morning and slit/drifted one near the end of the bar. Then I ground, sanded, and filed cold till I got a reasonable shape. Then, reheated and wire brushed. If there is another, better way, I'm from Missouri. Zeroing in on the corner of the stock with a slit chisel is iffy at best, so I flattened the opposite corners a little bit to help center the chisel.
November 1, 201411 yr Thanks! I was hoping there was some easy trick, but is there ever? I'll just have to practice more.
November 13, 201411 yr Great stuff Frank, as always. I'd lost track of Winslow a few years ago. Will have to track him down.
