need ifo on Alldays&Onions 1cwt hammer
Thanks alan
That actually helps a great deal.... ive been thinking of making the clearance about 0.3mm so the info you gave me confirms what i thought it should be.
now for the machining.....
just about finished hollowing out the billet , just have ti cut the flat , OD and tool holder....
will post pics when done...
oh , and some video..
My measurements may be a bit off and 0.3mm sounds a lot better than 2.5mm!
Alan
I know you are well along the way now, but did you consider getting the tup metal sprayed and then machining back?
I don't know anything about the process but it may have possibilities.
Would have saved you a lot off boring work! :)
Alan
Yeah , sort of considered it untill i had a llok at it after i clraned it up and saw that the cap at the top had been weld repaired and has a million cracks in it.....
Fair enough!
Three or four years after I had built the new workshop around the 3cwt, we were forging away and started hearing an extra knock, found the wedge loose so tightened it up, after a couple of blows the knock was back and the wedge was loose again, huh?  I had a look and discovered the front dovetail lump on the tup was cracking off…aaagh!
Couldn't face dismantling the workshop to put in a different hammer…but when I looked a bit closer I could see that it was a weld that was opening up…Huge relief, if it could work for at least three years with a weld then I could also just repair it now and then. We cleaned it up vee-d it out and TIG welded it with 312 rods and it has been working fine for the last 16 years or so.
The only other problem I had was the cylinder head cracking, and we machined one up out of a bit of 3" plate…
The only other problem I had (this is the third now in 20 years of use of a 60-90 year old machine!) was that my assistant assiduously greased the motor bearings too often and the grease got into the windings and I had to have it rewound :(
Rubbish reliability really!
Alan
  • 4 weeks later...
  • 1 month later...
ran it for the first time last night.....
had a blast...
will start some pics and video SOON....
Im a bit late to the party, but a good rule of thumb for most things power hammery is 0.001" per inch clearance. (bearings, pistons, rams etc !)
I cant believe it had worn itself 0.100" clearance on the steel ram and only a few thou in the (much softer) cast iron cylinder. It must have been monkey'd around with by a previous owner, ram from a different machine or something !
Look forward to the vids :)
