BECMA forges?
Doest anyone have any expierience with these?
I was looking around the net for a new firepit for my forge, and I found these on http://www.oezwerk.de/epages/62230868.sf/de_DE/?ObjectPath=/Shops/62230868/Categories/%22BECMA%20Schmiedeeinrichtung%22/Schmiedefeuer_mit_Geblaese
Which seem to be dirty cheap compared to other shops like "angele".  which raises the question: are they worth anything or are they garbage?
I'll certainly look forward to hearing your thoughts after you've worked with it for awhile.  Most of the commercially-available fire pots in the US are either .5", or .750" for their "heavy duty" models.  If you're just doing hobby smithing for a few hours a month, a .5" thick pot will last you a lifetime.
  • 2 weeks later...
Ordered this one last weekend:
It was delivered yesterday! extremely fast service.
I didn't install it yet as I still need to break out the old one.  I'm also planning on taking some pictures etc since I couldn't find any reviews of BECMA forges.  This way I hope someone else might benefit from this info.
So far it looks ok.  Looks to be kaowool in between the different parts.  At least I hope it's kaowool and not some type of foam xxxx :D
Thickness of the pit is 1.2 cm or about 1/2 inch.
So far the main things that bother me:
- the bolts to attach this thing seem to be missing... which is a bit of a bummer since they mention on their website that they are included.  I unwrapped it quickly to inspect it for damage since the packaging was a bit damaged.  Maybe it's still in some plastic wrapping somewhere.  The box was stuffed with it, they did a good job packaging it.  With a bit of luck it's in there somewhere.  I'll take another look tonight.
- the area of the fire pit around the hole (where the ball that regulates the air fits in) seems to be thin, which worries me a little bit.  I don't have enough experience with forges to know if this is normal or not... I guess we'll see.
I'll snap some pictures tonight.
attached the blower, and lighted it for the first time.  Works way better then the previous setup, but then again, the old firepit completely broke in two and the old blower was kind of broken too... :D
sorry for the mess in the pics, it's still a bit a work in progress :P
post-47554-0-68331900-1400945938_thumb.j
post-47554-0-67709200-1400946035_thumb.j
