Eddie Mullins Posted April 30, 2014 Share Posted April 30, 2014 I got my side draft built a couple of weeks back. Based on Hofi's design. Box is about 13 1/2" square and a little under 4 ft long. It is made from scrap sheet from hog pins, the same as the forge pan. I added the front panel with 8 x 10 opening after seeing fieryfurnace's on here. Not sure if its actually neeeed, but it works well. Chimney is a 10 ft long piece of used tin rolled up and screwed together to form a tube about 11" in diameter. Only expense was consumables, paint and welding wire. It has much improved my forging enjoyment. Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 30, 2014 Share Posted April 30, 2014 Looking very effective Eddie! I love how side drafts draw, makes me want to make one to look like a face sucking the smoke in. Like a B movie demon sucking the life out of a victim. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
VaughnT Posted May 7, 2014 Share Posted May 7, 2014 Looks great. I agree that you should do something to the front so that it has a gargoyle/demon face. The way it's sucking that smoke out is very impressive. Quote Link to comment Share on other sites More sharing options...
Eddie Mullins Posted May 7, 2014 Author Share Posted May 7, 2014 Thanks guys. A face sucking in the smoke would be pretty cool and actually wouldn't bee to hard for this one. I made the front so that is slips off if I need to modify or if ever needed for cleaning or repair, etc, its held in place by 4 tabs, 2 on each side. Quote Link to comment Share on other sites More sharing options...
