iron quake Posted April 29, 2014 Share Posted April 29, 2014 Finished my Brian Brazeal style striking anvil. I made the upper section from 2 sections of 2"x 3" CRS that I picked up as rem. from my supplier for 35 cents a pound. I machined the hardy holes in the mill as a matched pair. Grooved the intersections deep and then welded them all around. Should work ok, now I just need a striker. Quote Link to comment Share on other sites More sharing options...
yesteryearforge Posted April 29, 2014 Share Posted April 29, 2014 Nice Job That should work well Quote Link to comment Share on other sites More sharing options...
Eddie Mullins Posted April 30, 2014 Share Posted April 30, 2014 I will be making one of these as soon as I source some good material for the legs. Yours is the first I have seen use heavy angle like that, I might steal the idea. Are my eyes playing tricks on me, or is one of your hardy holes retangular? If so, do you have an anvil with a rectangular hardy or what was the reasoning for it? Quote Link to comment Share on other sites More sharing options...
iron quake Posted April 30, 2014 Author Share Posted April 30, 2014 Hi Eddie, Yes that's a 1" x 11/2" oversized hardy. One of the reasons for making this anvil is I'm going to be banging the same size mortise "hole" in some 1" X 11/2" or 2" bar. So as soon as my H13 material shows up I'll be making punches, drifts and giving this a go. As for the legs their 4" X 6" X 3/4" angle 40 lbs. each. I had that angle for a farm implement project that never got built, so I used it and think it turned out well. The anvil weighs about 150 lbs. I had to lift it off the welding table with the tractor. Quote Link to comment Share on other sites More sharing options...
VaughnT Posted May 1, 2014 Share Posted May 1, 2014 Very nice design. I would never have thought to use angle for the legs like you did. Ingenious. Quote Link to comment Share on other sites More sharing options...
