November 21, 201312 yr I just got a Hay Budden with some numbers that I could use some help with. Under the name is the numbers 312. Under the horn I found A31238. Does someone know what these numbers stand for? Thanks in Advance.
November 21, 201312 yr A31238 is the serial number it can tell you the manufacte date. The 312 may be a weight.
November 21, 201312 yr 312 *should* be the weight and as an American anvil it's NOT in CWT; so 312 pounds.
