log splitter
TJ Smith
Greetings Gents,
TJ...    Hydraulics don't care about distance...  Look at the line length on an excavator..   If you have a tractor with hydraulics you could put quick change fittings on the splitter and plug her in.
Dodge....   Most splitters require at least 5hp engine  ...   A 5hp electric motor would require a bunch of juice and is quite sizeable..
Now that you mention a splitter inside ..  Not this time of year but in the spring people sell the 3 point splitters cheap...  HUMMMMM..  IDEA..
I hope this helps someone..
Forge on and make beautiful things.
Jim
I put a 3 hp 240 volt moter and a 11gpm pump on mine.  Works great. 3 hp electric equals 5 hp gas
 I like this and don't forget many a blacksmith has built a hydraulic press with a 5 hp motor! Draws no more current than a 5 hp motor on a wood splitter ;)
Thanks guys.
Just another idea.
I am working with a 20 ton air over hyd jack mini press . It works. But always trying to have better and faster equipment..
Probably would be better if I made knives instead of equipment.
Ok where's that craigslist at.
Take Care
TJ
