Diamondback metalsmith burner problem
lloe01
My metalsmith forge has two burners. It has worked great for a year. Today, I could only get one burner to work. I think the burner jet is clogged. They use a pipe with a tiny hole in it. Does anyone know what size this tiny hole is or should be?
Thanks
Larry
Wasps and spiders will occupy, nest or put a egg sack in any small opening.  Birds will build nests in the forge body in a day. Wrapping the whole thing in a trash bag is the only way to store it in a shed.
If compressed air does not clear it, dis-assembly and small wires/toothpicks/tube brushes are in order. The mud from potter wasps is especially hard to remove, their saliva hardens it like cement. A soak in hot, soapy water helps.
