Anvil weight
I love broken anvils as they are often GREAT workers at *cheap* costs
They are especially good for working with untrained strikers---very relaxing to not be worrying about a sledge on the heel! (Going to be working with my pastor to forge down some RR spikes for "large nails"  picked up a blade from a piece of dirt equipment that has  nice sq holes that fits the HC rr spikes to use as a header too.
We'll be working on my 130# Powell that used to be 138#  before heel loss,,,
  • 4 weeks later...
Hi there John,
the first number is the amount of hundred weights (one hundred weight = 112lbs), the second number is the amount of quarter hundred weights ie. number x 28lbs) and the last number is the amount of single pounds. Add them all together and you get your weight of anvil.
eg. 1 3 18 would be 1x112lbs plus 3x28lbs plus 18lbs = 214lbs ...............as "Old South Creations" stated above.
Cheers, J
