Adhamh Posted August 27, 2013 Share Posted August 27, 2013 Hi, I picked up these two pieces today: Looks like an anvil to me! However I need to fill it with something. I was thinking maybe just some Portland cement. Right now it's not heavy enough so it bounces. I also didn't want to fill it with something that will kill the bounce. Suggestions? I also need to mount it so that I don't hammer bent over on the floor, and punch a couple of holes in it. Thanks. Quote Link to comment Share on other sites More sharing options...
Ridgewayforge Posted August 27, 2013 Share Posted August 27, 2013 I don't exactly know if that will work. With the metal being struck, the cement would disintegrate. Basically, you'd have a sandbag to hammer on. There would be little rebound. If you call around to machine shops, you might find some off cut chunks to use as an anvil. But, I would discourage using pipe. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted August 27, 2013 Share Posted August 27, 2013 get a solid block of steel for an anvil not hollow Quote Link to comment Share on other sites More sharing options...
Adhamh Posted August 27, 2013 Author Share Posted August 27, 2013 Well, crap! I was really hoping this would work because it gives me a face and horn. Quote Link to comment Share on other sites More sharing options...
ThorsHammer82 Posted August 27, 2013 Share Posted August 27, 2013 Nope, it give you a could sections of tubing. Horns are nice but not needed. Get a solid section of large round stock. Mount it securely and than you can use the side as a horn. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted August 28, 2013 Share Posted August 28, 2013 At least you didn't put a lot of time and money in it before you figured out it wasn't a great idea. But the tubbing is still good suff, put it in the materials pile. Quote Link to comment Share on other sites More sharing options...
