August 16, 200718 yr Is there any such thing available from metal supplliers and if so what sizes and, be careful note my wallet just went through fourpull bye pass; how much.!!!......... Duck
August 16, 200718 yr Speedy Metals - 110Order Copper Metal Pack, Plate, Rectangle, Round, Sheet, Square, Tube Alloys , 110, 122 in Small Quantities at OnlineMetals.com Here's two links to suppliers of coppper rod.......1/2" dia was about $0.84/inch
August 16, 200718 yr Then of course there is the salvage yard. You scrounge around and find what you need and pay by the pound. Not always the cleanest stuff around but sometimes cheaper.
August 18, 200718 yr Stores like Lowes and Home Depot have both small diameter round stock in the wiring section as solid ground wire, and larger (maybe 1/2" diameter) stock in the form of grounding rods. Pam
August 18, 200718 yr Care should be taken on the 1/2" round stock grounding rods, many are copper coated iron rods. I thought I made a great score on about 10 of these rods only to find they are not much use other than to bend cold. The ground wire is great because it is almost pure copper. Another use is for "penny welding" Another good source is copper pipe. A 3" pipe cut along its length will yield a flat piece almost 9 1/2" wide. Anneal before cutting and flattening.
August 18, 200718 yr Storm Copper (stormcopper.com) has almost every kind of stock available...not always the cheapest, but good service.
August 21, 200718 yr Author All the right answers in one website Thanks for all the responces.........Duck
August 22, 200718 yr sfduck, like mentioned above, try the scrap yards. I bought a piece of 1"x3"x12", nice CLEAN copper. best I remember I paid $2.50/lb==$32.00worth! They had several pieces of it plus some 6"rd and 8"rd, both about 10-12inches long....I passed on them! Check your area, there may be a company doing industrial electrical work that will sale you some of their scrap. Will really go a long way if you tell them what you are doing.
