August 15, 201312 yr This is my first forge took me a couple of days, and 40 dollars to build. Tell me what you think.
August 16, 201312 yr Rebar is very incansistant, Kay other steels I've difrrantly. Now that you have her up and running, might want to build a set of legs. Set it at anvils high.
August 16, 201312 yr You might want to make your tuyere longer. as I've noticed mine gets hot enough to melt plastic and it's further away than yours. As for the anvil, I'll be be best suited by standing it vertically. gives you the most mass under the impact point.
August 16, 201312 yr Looks a lot like the first generation of my forge. I agree with ThorsHammer - make the tuyere longer. Also, I cut a hole in the bottom of a soup can that slipped over the tuyere and the nozzle on the hair dryer. Only seconds to set up and take down, and you don't have to fuss with tape (if that's what you used. I'm not 100% sure from the pic). I used the angle iron from a bedframe or two that I got for free from Craigslist to make a forge table. You could also make a stand for the firepot out of the same stuff if you like. I made my forge in two pieces (table and pot) so that I could move it around easily. If you don't weld (I don't), it's pretty easy to drill a few holes and bolt it together.
August 17, 201312 yr Instead of raising your anvil and forge, why not go with the Eastern route and keep it low. All you have to do is sit down on a comfy stool and your anvil will be at a great height. There are tons of videos on the net showing third-world smiths doing great work while sitting and squatting! Stand your track anvil on end, secured to a 4x4 that's buried a bit, and you'll have a stable, relatively quiet anvil that's as good as you can ask for. And it will be more efficient!
