New antler handle knife
eseemann
Good Eve all,
Still trying to work the kinks out of the mounting of blades in to antler. Here is one I did today. I am not happy with how much I ended up grinding off the tang. Please take a look and let me know if you guys think this is too narrow and may not be a strong enough tang. The blade is pinned in with a brass tube and the void, after the pith was drilled out, was filled with poured pewter.
thanks for any suggestions or feedback.
post-35414-0-31701800-1372036067_thumb.j
post-35414-0-60406600-1372036082_thumb.j
post-35414-0-54006100-1372036110_thumb.j
post-35414-0-99644100-1372036135_thumb.j
post-35414-0-85777900-1372036151_thumb.j
post-35414-0-60098000-1372036168_thumb.j
It will help you to make a guard of some kind.  some 1/4" thick brass stock fitted to the tang will go along way to help .  The other thing it to solder a peice of 1/4" threads and make a butt cap.  With that set up you'll need to fit everything up good but the end product will look reall clean.  In the end it seams to me easier to do it that way, that's why I use that method.
