12 tonHydraulic presses?
Årvik
Ah well have a look at some of the home builds on here I am sure something will catch your eye.
The main drawback to using such a press for hot working is they are too slow. Better for cold bending, pushing off bearings and etc.
You might check out second hand tool dealers if you want a forging capable press.
If you look at the thread about bowl making tools started by Kurgan, I posted a link there to a couple of videos of my bowl tools on my old 12 tonne Hi-Ton press..that cost me less than 300 sterling and is fast enough for hot work. I have punched and drifted Ø50mm holes through 50x50mm steel with it....
Alan
  • 1 month later...
