Fe-Wood Posted March 27, 2013 Share Posted March 27, 2013 I'm looking for a replacement drive pully for my compact 200# Bradly. I'm also looking for a seamless drive belt supplier. Quote Link to comment Share on other sites More sharing options...
doc Posted March 27, 2013 Share Posted March 27, 2013 http://www.beltcorp.com/products.html?_vsrefdom=ppcgoogle&gclid=CPTw3L3znLYCFckx4AodinwApg Try starting here for endless belts,otherwise just Google endless belts. Quote Link to comment Share on other sites More sharing options...
mike-hr Posted March 27, 2013 Share Posted March 27, 2013 FE, if your drive sheave quest comes up dry, I'm sure we could make you one in a day if you drive north a bit. Quote Link to comment Share on other sites More sharing options...
Fe-Wood Posted March 29, 2013 Author Share Posted March 29, 2013 Thanks Mike! You comming to Placerville? Quote Link to comment Share on other sites More sharing options...
harrismetalsmith Posted March 29, 2013 Share Posted March 29, 2013 What's the diameter of that pulley? And shaft size Quote Link to comment Share on other sites More sharing options...
r smith Posted March 30, 2013 Share Posted March 30, 2013 what is wrong with the one pictured? Quote Link to comment Share on other sites More sharing options...
Fe-Wood Posted March 30, 2013 Author Share Posted March 30, 2013 Harrismetalsmith- Shaft size is 2" diameter and the overall diameter is 7". r smith- Look closely at the pictures and you can see cracks in the skin. These pullies are the clutch and this one is worn very thin. Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted March 30, 2013 Share Posted March 30, 2013 Greetings FE, Your pulley is a common line shaft pulley design... I have a line shaft shop and have several but larger diameter.. Most of the time they have a split locking hub inside... I suggest you take it apart and look and measure.... You can try looking on ebay under line shaft or flat belt or hit and miss engine... Try your local early engine clubs for a sorce... Good luck Jim Quote Link to comment Share on other sites More sharing options...
r smith Posted March 30, 2013 Share Posted March 30, 2013 Thanks Fe, I could not see that on my screen. Quote Link to comment Share on other sites More sharing options...
Dillon Sculpture Posted March 30, 2013 Share Posted March 30, 2013 Can you just sleeve the one you got, with some thin sheet metal? Quote Link to comment Share on other sites More sharing options...
Fe-Wood Posted March 31, 2013 Author Share Posted March 31, 2013 Thanks for the suggestions all. I'm thinking sleave but if I can come up with another one for a reasoanble price, I'd do it. Quote Link to comment Share on other sites More sharing options...
peacock Posted March 31, 2013 Share Posted March 31, 2013 I fix those by wraping it with leather. skive the ends for a smooth lap joint. contact cement it then put a row of screws thru the lap. Make sure to wrap i the correct direction so the belt will be laying the edge down not trying to peal it up. They last for years. Quote Link to comment Share on other sites More sharing options...
