Untame Posted March 11, 2013 Share Posted March 11, 2013 This anvil is 24" long and 117 pounds. It has a 1" hardee hole right through the middle, and four "sides" each with a different radius profile. Anyone ever seen anything like this? Quote Link to comment Share on other sites More sharing options...
Timothy Miller Posted March 11, 2013 Share Posted March 11, 2013 The french use a tool like this for forming sheet metal. I don't know much else about them or how they were used. Quote Link to comment Share on other sites More sharing options...
Ridgewayforge Posted March 11, 2013 Share Posted March 11, 2013 Looks like a good anvil! Quote Link to comment Share on other sites More sharing options...
Untame Posted March 11, 2013 Author Share Posted March 11, 2013 The french use a tool like this for forming sheet metal. I don't know much else about them or how they were used. Thanks, Timothy. The guy I bought it from (for $60) said that it had been used to shape sheet metal at a freezer fabricator. I can see many good uses for it forging. I need to rig up a stand that lets me rotate it and lock it into place for each of the profiles. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 12, 2013 Share Posted March 12, 2013 Lots of sheet metal forming stuff is just cast iron and won't hold up to heavy smithing hammering. Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted March 13, 2013 Share Posted March 13, 2013 Greetings, It looks to me like the intended use was in a vertical position... The square mounting hole is in the end... It does not look like it has had much hammering or use.. Many factory tools are made for a single use and than discarded... It looks to be cast iron and if it was mine I would test it before much use... Have you ever seen a stove pipe anvil ? Jim Quote Link to comment Share on other sites More sharing options...
Untame Posted March 13, 2013 Author Share Posted March 13, 2013 I was a bit wary buying it. I bounced some steel on it before I picked it up, and it seemed to ring clear, but I'm just a novice. I don't think it is cast iron. Quote Link to comment Share on other sites More sharing options...
Timothy Miller Posted March 13, 2013 Share Posted March 13, 2013 The one I saw was forged steel. Quote Link to comment Share on other sites More sharing options...
