Lodestone25 Posted February 23, 2013 Share Posted February 23, 2013 I'm definitely still a rookie - just trying to push my boundaries a bit with this project. This is my first attempt at a chandelier, not complete yet by any means, this is just the "core". I'm planning on adding some banding and detail scrollwork along the middle cylinder section (as well as candleholders at the ends of the arms). I have a whole bunch of process pics here, I just wanted to see if anyone had any input as to things I could do better, things I did right, and maybe any ideas for what kind of detail pieces I could add to "fill it out" Thank you for your help! Lodestone Quote Link to comment Share on other sites More sharing options...
yves Posted February 23, 2013 Share Posted February 23, 2013 I'm definitely still a rookie - just trying to push my boundaries a bit Youre pushing in the right direction! I like the Hydra at the top, the movement. A lovely piece. Quote Link to comment Share on other sites More sharing options...
Paul Crosby Posted February 25, 2013 Share Posted February 25, 2013 I like the design and the quality of work is outstanding. Quote Link to comment Share on other sites More sharing options...
Lodestone25 Posted February 26, 2013 Author Share Posted February 26, 2013 Thanks for the feedback guys! I was trying to figure out whether or not to see if I could run electric candles on this thing in the end, but i might be out of luck since I used solid stock instead of tubing. Do you think I'd be able to run thin black wires through the center cylinder and out to provide electricity to the ends? Or do you think that would end up looking bad? Otherwise I'll just have to go with good old fashioned candles, which i think would look nice as well. Lodestone Quote Link to comment Share on other sites More sharing options...
gearhartironwerks Posted February 27, 2013 Share Posted February 27, 2013 You might consider a copper wrap about 2/3rds the way up the stem using 10 ga. wire. It gives a nice contrast to the steel. If you decide to do this, initially wrap the copper around a 1.5" dia piece of tubing estimating how much you will need to cover the space you decide, then put the tube/copper in the forge till almost red, and quench immediately. That will anneal the copper and make it much easier to wind around the stem. When I do this, I tuck in the ends and silver solder with low temp silver to hold them. Good luck and it's looking good so far. John Quote Link to comment Share on other sites More sharing options...
gearhartironwerks Posted February 27, 2013 Share Posted February 27, 2013 Sorry...I forgot to answer your query about wiring. The very first decision to be made when building a chandelier/sconce is whether it's candle or electric. Candle is always easier, but most folks want electrified. If that is the case, you need to determine where/how the wiring will go. I use tubing whenever possible and often scale it up in the forge to give it the forged look. That being said, it is not always possible to use tubing and the wiring must go on the outside. This is pretty common on European pieces that are forged and is completely acceptable in lighting design. John Quote Link to comment Share on other sites More sharing options...
Lodestone25 Posted February 27, 2013 Author Share Posted February 27, 2013 John, thanks so much for the tips and input! I'll look into the copper wire wrap idea, it sounds like it would be a great touch. As for wiring, I'm thinking right now I'll try to make it electric and hide the wires the best I can, and if it turns out looking bad I'll just switch to candles. Thanks again John, your insight is much appreciated! Lodestone Quote Link to comment Share on other sites More sharing options...
bosox Posted March 5, 2013 Share Posted March 5, 2013 I would like to see it in person because the photos probably hide some of your craftsmanship. You did a very good job on that! Quote Link to comment Share on other sites More sharing options...
