Building a forge
hello all who read this i am here to learn first how to build my own forge blacksmithing or more to the point swordsmithing have always interested me and i would be grateful for any information that i can get from anyone here thank you
iwant to start making things from metal otherwise known as blacksmithing i am unfortunately very ill educated though if someone could tell me how to build my own forge i would be very grateful
Hi bighammer24
Youll find a lot of info in the blueprint section on building forges. Im also new to blacksmithing and have just built my first forge. I use anthracite for fuel mainly because thats what i have available. Basically my forge is just a pan for fuel with a pipe T at the bottom for airflow and to allow the ash to fall down into a bucket or drum. I use a vacuum machine motor for airflow, it sits on the inside of a pipe 6" that ive reduced to 2" for airflow. It also has a valve so I can control the airflow. Thats basically it. Good luck and welcome to the forum.
Bb
