July 2, 201214 yr The camp axe is 1045 with a 5160 bit welded in..The bag axe is 4 piece construction of wrought iron and a W2 cutting bit..
August 13, 201213 yr I beleive that it is an axe small enough to throw in your backpack or "bag" when you are not using it
October 10, 201213 yr I keep coming back to this thread if it was only to study that first pic.... That is a real neat piece of work that, I do like the shape and the woodwork and maybe someday I might have a go if ever I land a power hammer to break the back of most of the shaping. Maybe if you have a minute, could you be so kind as to explain how you would go about forging an axe head like that in the first pic? I may learn something here, thanks
October 17, 201213 yr Author Well highsider that started out as a 1" square bar of 1045..It was upset for more blade mass then a cutting bit of 5160 was welded in..The eye was slit and drifted..I think we may have a pic or two..let me look..
