Kwisatz Posted June 29, 2012 Share Posted June 29, 2012 Made from a lawnmower blade a friend gave me, this knife is just at the uppermost limit of size and weight that I can effectively wield one-handed. It weighs in at a nearly unheard of weight for a knife, 1 pound, 10.5 ounces! I added my Nordstroms card to give you a sense of scale. ~Total Knife Length: 1 ft. 1 in. Blade Length: 8 ½ inches. ~Blade Width: 2 ½ in. ~Handle width: 2 ¼ in., tapering to 1 ¼ in. ~Handle Length: 4 ¼ in. ~The spine of the blade measures ¼ in thick, and then it explodes into a 1 ¾ in wide handle. It’s a Full Tang knife, meaning that the blade extends through the length of the handle and had six pins to keep it secure. I can chop down a tree with this thing and my arms would give out long before the blade would ever even wobble. The handle is made from the slats on an oak bed. I bought epoxy from the Dollar Store and stuck a slab on each side of the blade. I sanded it down to a rough shape with a file from the Dollar Store, then sandpaper…from the Dollar Store. The six pins were cut from plain, brown hangers. The kind I get from the drycleaners. Some have a plastic coating. I avoided those. I drilled holes, and added a drop of superglue from the Dollar Store to the hole before hammering them in. I added a few coats of brown wood stain, letting it dry overnight before each new coat Then I sealed it with two coats of triple-thick Krylon glaze. I wanted a worn, aged look to the handle. It worked! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 29, 2012 Share Posted June 29, 2012 Looks rather like a shiv on steroids! Quote Link to comment Share on other sites More sharing options...
Kwisatz Posted July 1, 2012 Author Share Posted July 1, 2012 Looks rather like a shiv on steroids! Shiv on ‘roids. Now that you mention it, the description fits! Quote Link to comment Share on other sites More sharing options...
