Gundog48 Posted May 11, 2012 Share Posted May 11, 2012 I finished the forging and rough grinding of my first ever blade today and I am extremely happy with it! Other than a punch, this is the first thing I have forged and I don't think it could have come out better for a first attempt, it's cleaned up really well. I forged it out of a length of a starter motor ring gear into a bowie style using mole grips and a 2lb ball peen hammer. I've finished the shaping, refined the profile and ground out all the pitting, but I am left with one problem before I can heat treat and polish it- the bevels. I've removed the side guard from the bench grinder so I have a nice flat edge that has worked well for the rest of the blade, however the real difficulty is finding the right angle to grind at, and to be able to keep it at the same angle the length of the blade to give it a nice neat line. What would you recommend for this? Because it is a bowie-style knife I want the bevels to start at a certain point down the blade and for them to be straight. How would you go about doing this with my particular setup? Would files be a better option, or would it be best to save up for a belt sander? I'll be sure to post pictures when I'm done, I'm really proud of it so far for a first attempt! Thanks, Jake Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted May 11, 2012 Share Posted May 11, 2012 i tried thatlong ago and gave up on a bench grinder for knves. I use a belt grinder,,However you can anneal the blades and use files . Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 11, 2012 Share Posted May 11, 2012 You might check the set up in "Step by Step Knifemaking" as he used a bench grinder. NOTE working on the side of a grinding wheel designed for use on the edge IS NOT SUGGESTED! Failure modes are quite nasty!. Quote Link to comment Share on other sites More sharing options...
Loneforge Posted May 12, 2012 Share Posted May 12, 2012 I rough forge my bevels in! Anneal then attack with files.....Painstakingly satisfying! Quote Link to comment Share on other sites More sharing options...
Jon Smith Posted November 8, 2012 Share Posted November 8, 2012 Agreed. Forge the bevels in with a hammer by leaning the blade slightly on edge on the side of the anvil so you can do both sides at once. Then anneal and draw file. Hard on the hands and back but oh so satisfying Quote Link to comment Share on other sites More sharing options...
