Flowers for Mother Not
Beth and Marksnagel,
Thank you
The flower blanks were drilled and the stems were worked leaving enough material to rivit the head for the centers. What a pain. I thought that the material would swell and hold but I ended up welding them on the back side. I will also work the edges more and thin them down before trying to flower them up. I think that they are too thick on the edges. Once you do one you got to do them all the same way. I also tried a wax mix finish. Ended up kind of sticky. Maybe not enough heat. I have had requests to make make more. Should go easier.
