Integral Tomahawk Tutorial
When i posted the first one of these, I got alot of "how the heck did you do that?!" responses, and while I explained it well enough I thought a picture is worth a thousand words, so here's a million.
I have thought and thought on how to do this for awhile, sketching out different ideas over and over on how maybe to split, cut, fuller and squeeze out one of these from a single piece of stock, and this is what I have settled on.
First, oil up the powerhammer
400445_3108966614084_1561909122_2969514_
I start with new drops from a spring shop, spring steel made in USA. It is 3/8" thick by 3" wide
400418_3108966654085_1561909122_2969515_
400445_3108966694086_1561909122_2969516_
and here is my setup. I utilize the Swage block for the upsetting, my regular anvil, my NC forge for the long work, my Mankel for the wide work, and different hammers and tongs.
400445_3108966814089_1561909122_2969517_
and of course sledgehammer :D
400445_3108966934092_1561909122_2969518_
First step is to neck down the bar and begin to forge the handle, it was quick work on the Say Mak 110 but takes a few more heats on the Anyang hehe but it does surprisingly well on such wide stock.
396137_3108977374353_1561909122_2969520_
396137_3108977414354_1561909122_2969521_
396137_3108977454355_1561909122_2969522_
396137_3108977534357_1561909122_2969524_
And there we go, 1" wide by the orignal thickness 3/8".
402054_3109000734937_1561909122_2969535_
And then cut off from the parent bar, making sort of a lolly pop. The dimensions of the end bit are 3" wide by 3 1/2" long
402054_3109000774938_1561909122_2969536_
Grind the end clean
402054_3109000934942_1561909122_2969538_
And switch over to the Mankel. I wish I had a coal forge setup for this then I wouldn't have to switch.
404844_3109010215174_1561909122_2969539_
Now we start to upset the lollipop in the swedge block.
404844_3109010295176_1561909122_2969540_
This makes for some nasty corners so grind them clean and resume upsetting
404844_3109010335177_1561909122_2969541_
404844_3109010375178_1561909122_2969542_
404844_3109010455180_1561909122_2969543_
I begin also to come at an angle into one corner, to start pushing extra material to one side, as the blade needs more material then the spike. I do this coming in at an angle onto one side.
399823_3109025175548_1561909122_2969545_
403312_3109034695786_1561909122_2969552_
As I am upsetting I keep going under the powerhammer and flattening things out as it will bend and mushroom over, keep it clean and inline and upsetting need not be so upsetting :D
399823_3109025335552_1561909122_2969549_
Also the swedge block has slightly radius inside corners, this prevents a shearing action and also from those inside corners from getting sharp and forming cold shuts, a nice radius is good
399823_3109025255550_1561909122_2969547_
Now is the time I wish I had a striker. Once the Hawk head is upset sufficiently I flip it over and begin to work in the beard and angles in the "neck" area. I work in with the cross peen, then flattenm, then cross peen, then flatten, then cross peen, then flatten, and keep doing this until it's the shape I want.
403312_3109034855790_1561909122_2969556_
402471_3109044056020_1561909122_2969559_
Next day (today), I did a bit of geometry refinement, to make it a nice tough chopper, and began filework.
403172_3109098537382_1561909122_2969594_
I draw a chalk line up from the handle to use as a guide for an artistic break in the beveling I file all around. I do this all by hand with different files, it is not as quick as the grinder but FAR more controlled, I have alot of work into it up to this point and I do not want to risk ruining it on the grinder. I find it very peaceful to file all the bevels.
418308_3116420520427_1561909122_2971587_
I file in to start the sharp corners, then begin beveling.
425147_3116421680456_1561909122_2971590_
418131_3116421280446_1561909122_2971589_
419843_3116421840460_1561909122_2971591_
417857_3116422080466_1561909122_2971592_
And filework is mostly done. I will continue it down the handle shaft about 1/3.
429389_3116422880486_1561909122_2971594_
And now some fun photos :D
the integral battle playset
426154_3116423640505_1561909122_2971596_
402239_3116425080541_1561909122_2971599_
427767_3116448961138_1561909122_2971601_
hi Sam,
Great tutorial! Sam remember the side set I gave you, you may remember my showing you the double one made like a spring tool? If you take the time to make one of these up and use it to do your initial necking at the base of your lollipop it will help eliminate some of the burring and folding that occurs when you go to do your upset.
Great job, wonderful presentation speak to you soon.
Doc
It is very interesting to see how you approached this Sam! Thank you very much for taking the tme to share it with us! I am thinking that given the same stock I would likely try a different technique. I know that what you have done here will stick with me though and I'll use it somewhere! I am thinking that I'd make the stock end the cutting edge and chisel the spike out of the handle side of the stock and then upset and bend the blade around till it is perpendicular to the handle. THEN I would draw out my handle. That way the stock chiseled out of the handle for the spike would not be missed as I would just draw it out less in that area. I might have to give this a try! Whether I get to it or not though, thank you much for the inspiration and sharing your skills with us!
Since you posted pics of your first Integral Tomahawk, I've spent many waking hours wondering how it was done. I thought maybe splitting off a small sliver to form the spike end, but that has proven to cause a stress crack that is hard to stop. At least it has in some of the cleavers I've made. But that's a different story.
Your tutorial shows why you are an excellent teacher. Thanks for sharing this knowledge! I really appreciate the efforts you took to present such a well documented, and clear presentation. The pictures are worth a million words.
Robert
