Grumpie Posted December 6, 2011 Share Posted December 6, 2011 I wonder if anyone can help, I have just renovated and fitted a pair of Alldays and Onions double action bellows to my forge, unfortunately they came without the weights. I am using the weights from my flypress at the moment but the are a little light for the job. Does anyone know the correct size of the weights used originally, I have searched the net but have had no luck in finding out. Thanks :) Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 6, 2011 Share Posted December 6, 2011 I would assume that a smith would adjust the weights till they suited his working style and forge and not assume that one size weight would work for smiths with wildly different tue iron set ups. Quote Link to comment Share on other sites More sharing options...
John B Posted December 6, 2011 Share Posted December 6, 2011 I wonder if anyone can help, I have just renovated and fitted a pair of Alldays and Onions double action bellows to my forge, unfortunately they came without the weights. I am using the weights from my flypress at the moment but the are a little light for the job. Does anyone know the correct size of the weights used originally, I have searched the net but have had no luck in finding out. Thanks What diameter are the bellows. they came in different sizes? What is your location, I have one spare that I can weigh for you, or you can have if you can collect. Quote Link to comment Share on other sites More sharing options...
Grumpie Posted December 7, 2011 Author Share Posted December 7, 2011 Hi Thomas, the weights on these bellows are used to aid the up stroke, they fill the upper chamber harder on the up than the downstroke, and it can be hard work to push them up without the the weights to help Thanks John, I live in northeast Scotland so it is a bit out of the way, but it would be great if you could weigh it for me The diameter of the bellows is 28 inches. Thanks again. Quote Link to comment Share on other sites More sharing options...
John B Posted December 8, 2011 Share Posted December 8, 2011 (edited) Hi Grumpie, the bellows the weights came from were 25" diameter outside dimension 2 cast iron weights each weighing 16kgs or 36lbs total weight 32kgs or 72lbs.I assume these were the original ones as they worked OK with them, however they did rub on the sides of the leather when in use, and I modified them to stand off from any contact.Six and a quarter inches diameter, painted red. Edited December 8, 2011 by John B Quote Link to comment Share on other sites More sharing options...
Grumpie Posted December 8, 2011 Author Share Posted December 8, 2011 Thanks John, thats a great help. I will get some cast iron kettle weights from ebay now and modify them to fit :D Quote Link to comment Share on other sites More sharing options...
John B Posted December 8, 2011 Share Posted December 8, 2011 The ball diameters were six and a quarter inches with a loop cast into them to hang them, Oh, and painted red. Quote Link to comment Share on other sites More sharing options...
Grumpie Posted December 10, 2011 Author Share Posted December 10, 2011 Thanks for that info, I like things to look right :) Quote Link to comment Share on other sites More sharing options...
