Nakedanvil - Grant Sarver Posted November 19, 2011 Share Posted November 19, 2011 Got a new product line going. Starting with flatters, but I'll expand into a whole bunch of top and bottom tools now. Had what I thought was a pretty slick punching setup, but didn't work out as well as I had hoped, just having to take out too much material for the stock size. Got a good script going on the ol' CNC mill. Two machine vises with two parts each. Take just under 20 minutes. Allows me to forge for twenty minutes then change parts and go back to forging. Top tools don't require the hourglass hole like a hammer. Heck you're not even supposed to wedge them, just knock them on and off so you can dress them easily. Quote Link to comment Share on other sites More sharing options...
Frank Turley Posted November 19, 2011 Share Posted November 19, 2011 Fullers & swages will be inches or metric? Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted November 19, 2011 Author Share Posted November 19, 2011 Fullers & swages will be inches or metric?As a good salesman would say "What would you like them to be"? Quote Link to comment Share on other sites More sharing options...
BM454 Posted November 19, 2011 Share Posted November 19, 2011 That would be (yes). Depending on what you measured them with of course ;) Quote Link to comment Share on other sites More sharing options...
macbruce Posted November 19, 2011 Share Posted November 19, 2011 First rate job you did of grinding those welds, handles included? :lol: Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted November 19, 2011 Author Share Posted November 19, 2011 First rate job you did of grinding those welds, handles included? Easier to forge than to weld and grind! Yes, they come handled. These are little 1-1/2 inch flatters. Even if it wasn't easier, I'd rather forge than weld and grind...........any day! Quote Link to comment Share on other sites More sharing options...
Wesley Chambers Posted November 19, 2011 Share Posted November 19, 2011 Top tools don't require the hourglass hole like a hammer. Heck you're not even supposed to wedge them, just knock them on and off so you can dress them easily. Brilliantly simple concept I never thought about, thanks for the +1 wisdom Quote Link to comment Share on other sites More sharing options...
macbruce Posted November 19, 2011 Share Posted November 19, 2011 Easier to forge than to weld and grind! Yes, they come handled. These are little 1-1/2 inch flatters. Even if it wasn't easier, I'd rather forge than weld and grind...........any day! I knew that..... :P Quote Link to comment Share on other sites More sharing options...
Stormcrow Posted November 20, 2011 Share Posted November 20, 2011 Hey Grant, mind sharing what that eye punching setup was? Maybe it'll work on a smaller chunk of steel. I'm about to be building some eye-punching stuff for my press and think I know what to do, but it's always good to pick the brains of smart folks with experience. Quote Link to comment Share on other sites More sharing options...
Francis Trez Cole Posted November 20, 2011 Share Posted November 20, 2011 great work grant as always Quote Link to comment Share on other sites More sharing options...
joshua.M Posted November 21, 2011 Share Posted November 21, 2011 what will the cost for the flatters be? Quote Link to comment Share on other sites More sharing options...
forgemaster Posted November 21, 2011 Share Posted November 21, 2011 At last I have found someone else who does'nt advocate the wedging on of tool handles, thankyou Grant. With a guru such as you putting it in print my arguments will have just that more weight, "oh yeh but even the famous Grant Sarver does,nt wedge his tool handles on" there it is, done deal nothing more needs to be said! Phil Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted November 21, 2011 Author Share Posted November 21, 2011 At last I have found someone else who does'nt advocate the wedging on of tool handles, thankyou Grant. With a guru such as you putting it in print my arguments will have just that more weight, "oh yeh but even the famous Grant Sarver does,nt wedge his tool handles on" there it is, done deal nothing more needs to be said! PhilHa! And I can say "Forgemaster says so, so it must be right"! Great minds DO think alike! Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted November 21, 2011 Author Share Posted November 21, 2011 A little side note: these are as-forged 4140. I start with 1-1/4 round, forge the shank, drop it in a bolster and forge the flatter then machine the flatter end and the hole. After that it goes to the grind shop for chamfer, then paint and handle. Quote Link to comment Share on other sites More sharing options...
Dillon Sculpture Posted November 21, 2011 Share Posted November 21, 2011 What hammer do you use to make them if you use a hammer? Any images of the forging process? Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted November 21, 2011 Author Share Posted November 21, 2011 It's all done on my friction screw press. The process is exactly the same as the bottom tools that I have documented on Youtube. Quote Link to comment Share on other sites More sharing options...
joshua.M Posted November 21, 2011 Share Posted November 21, 2011 do you have a link to your youtube account handy? Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted November 21, 2011 Author Share Posted November 21, 2011 Sure! CLICK HERE! Quote Link to comment Share on other sites More sharing options...
bigfootnampa Posted November 21, 2011 Share Posted November 21, 2011 Nice looking tools Grant! Here's another idea for you: How about making hardy blanks where the tang to fit the hardy is rough forged and the mass for the base established but the tool portion just an unformed mass? That would give most smiths quite a head start and even guys with plenty of skill might find it handy to have a few of those blanks around for whenever they need a tool in a hurry. You could offer them in several common hardy sizes. Quote Link to comment Share on other sites More sharing options...
MattBower Posted November 21, 2011 Share Posted November 21, 2011 When I first saw the pics on a small screen, I thought you'd done a bunch of asymmetric cutler's hammers. Hint, hint. :) Quote Link to comment Share on other sites More sharing options...
