pete46 Posted February 11, 2007 Share Posted February 11, 2007 DOES ANYONE HAVE ANY IDEA WHAT THE NUMBERS MEAN ON LAWN MOWER BLADES? EXAMPLE: JBJ 9488 3362 I HAVE ALOT OF THEM & AM CURIOUS ? THE #'S GIVEN VARY AS DO THE LETTERS,BUT THE FORMAT IS THE SAME.:confused: Quote Link to comment Share on other sites More sharing options...
Woody Posted February 11, 2007 Share Posted February 11, 2007 Part #??????? Quote Link to comment Share on other sites More sharing options...
pete46 Posted February 11, 2007 Author Share Posted February 11, 2007 MAYBE, BUT THE SEPERATE # MAKES ME THINK STEEL TYPE? i.e. 1040,3xxx,6xxx? Quote Link to comment Share on other sites More sharing options...
Bobb Posted February 11, 2007 Share Posted February 11, 2007 Good Question I have a lot of these also. Where did you find this number? Around the shaft hole? Quote Link to comment Share on other sites More sharing options...
Glenn Posted February 11, 2007 Share Posted February 11, 2007 The metal for lawn mower blades has been discussed several times as well as what can be done to recondition or reuse them (as lawn mower blades). Think of this from the manufactures point of view, you want a metal that will deform rather than shatter or chip when it hits rocks or other things in the yard. It should hold only somewhat of an edge as you want the public to buy replacement blades if they get dull or deformed. What type numbers are you going to stamp on the product? I doubt that it would be the number for the steel used. It most likely would be a part number so the proper blade could be provided as a replacement. Quote Link to comment Share on other sites More sharing options...
pete46 Posted February 11, 2007 Author Share Posted February 11, 2007 Bob The #;s Are To One Side Of The Hole; Under The Paint. Glenn I Agree ,but Why 2 #'s? Quote Link to comment Share on other sites More sharing options...
pete46 Posted February 12, 2007 Author Share Posted February 12, 2007 A,man Did You See Any Numbers? I Know I'm Obsessing, But All The Other Places I Check Want To Sell Me Mower Parts! With No Clear Answers!!!!!!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Glenn Posted February 12, 2007 Share Posted February 12, 2007 Look where they would not wear off and remain visible when needed. Quote Link to comment Share on other sites More sharing options...
Woody Posted February 12, 2007 Share Posted February 12, 2007 According to my junkyard steel list lawnmower blades are typically 5150 or 5160, or at least they used to be no telling what they are made from now. What diffierence do the numbers make anyway. Take one, heat it non critical, quench in oil, then see if you can scratch it with a file, if not, it is pretty high carbon. After quenching if a file will cut it readily, it's pretty low carbon. If you are hung up on knowing exactly what steel you are working with the only way to be sure is to buy virgin stock that comes with a certificate of analysis. Woody Quote Link to comment Share on other sites More sharing options...
Dr Dean Posted February 12, 2007 Share Posted February 12, 2007 The first set of numbers is the part number. The other set is either a batch code or a date code. Really the only one that anybody cares about is the P/N espically when the fine gentelman at the parts counter gives you the wrong set for the 4th time. Quote Link to comment Share on other sites More sharing options...
pete46 Posted February 12, 2007 Author Share Posted February 12, 2007 Thank's Dr. Dean That Makes Sense! Now I'll Take Woody's Advice & See What I Have As Far As Steel!!!:) Quote Link to comment Share on other sites More sharing options...
blafen Posted February 12, 2007 Share Posted February 12, 2007 i got a lawnmower blade from my shop teacher and made it into a knife it hardened very well and is quite tough. Quote Link to comment Share on other sites More sharing options...
JerryCarroll Posted February 13, 2007 Share Posted February 13, 2007 I used lawn mower blade for making the furniture for a trade rifle. When I attempted to cold bend the trigger guard to fit it snapped like glass--same with the butt plate. I had quenched the finished pieces in water at just below red. There was more carbon or something added than I had read about in research. I shoulda done the test Woody recomends. Quote Link to comment Share on other sites More sharing options...
Jocko 58 Posted April 29, 2009 Share Posted April 29, 2009 maybe a part number Quote Link to comment Share on other sites More sharing options...
