Frank Turley Posted October 19, 2011 Share Posted October 19, 2011 I have an 8" Parker machinist's vise that has begun to require 1½ to 2 turns before it engages and tightens or loosens; kind of annoying. Is this typical of vises that have your everyday screw-and-slide? Is there a quick fix? I know I can take it apart to have a look-see. Just haven't got around to it. Quote Link to comment Share on other sites More sharing options...
Fosterob Posted October 19, 2011 Share Posted October 19, 2011 I have repaired similar problem vices with the addition of some proper size washers on the screw where it captures the moving jaw. The ones I had wore out in that area. Sometimes the nut is bolted in and comes loose as well. Rob Quote Link to comment Share on other sites More sharing options...
Fe-Wood Posted October 19, 2011 Share Posted October 19, 2011 sounds like it might have a screw loose Couldn't resist Seriously, I don't know the Parker brand but I do know many types of vises have a "keeper Plate" to keep the lead screw attached to the jaw. Also the threaded block in the body of the vice could be loose. Quote Link to comment Share on other sites More sharing options...
John McPherson Posted October 19, 2011 Share Posted October 19, 2011 I have had to take apart, repair and reassemble 6-8 quality vises here at work, and junk another half dozen cheap imports. (Students are hard on everything.) Most makes will just let you keep turning the screw until the front jaw comes off, be ready to catch it. There is usually a washer, spring, and U-clip that holds the front jaw to the screw that wears out or falls apart. There is also a bolt from the bottom of the swivel base that holds the screwbox in place inside the frame, sometimes that needs some thread locker to hold it in place if the vise is used for hammering or grinding work. The swivel plate locking bolts also need to be replaced if stripped or bent. They tend to be odd threads in old vises. Google image search did not turn up anything useful for Parker, but 'Wilton vise diagram' and 'Sears vise diagram' did. Quote Link to comment Share on other sites More sharing options...
