August 31, 201114 yr Sorry I was referring to Mick's "I think copper melts before brass. Keep an eye on it as there is a fine line between copper sweating and running out of the seams" Brass will be pooling in the bottom of the forge before copper sweats!
August 31, 201114 yr Oh, didn't see that. Absolutely right, Master Powers. If you use copper and brass you'll stop when the brass starts to sweat at the edges. With quarter mokume you watch for the copper to sweat, because nickel melts much higher.
