ironsmith Posted May 26, 2011 Posted May 26, 2011 Hey guys , Anyone ever use 1 inch ceramic blanket on propane forges? I have always spent the little extra to use the 2inch and it has served me well. Just bought a box online and they sent me 1 inch, not sure if it is worth sending back or just to try 2 layers of the 1inch... My one issue is if it will collapse down inside the forge. ( I use freon tanks as the body) well let me know your opinion please and thanks!!! Quote
pkrankow Posted May 26, 2011 Posted May 26, 2011 I used one inch in a similar sized vessel and 2 layers work nicely. No sagging, but it does not see heavy use. I suspect it is easier to manipulate than 2 inch. Phil Quote
tlreif Posted May 26, 2011 Posted May 26, 2011 I agree with Phil. I use 2 layers in both of my forges and it works very well. Quote
ironsmith Posted May 26, 2011 Author Posted May 26, 2011 Thanks for letting me know, Just got on the horn with a real person about them sending me the wrong order and they seem to be easy to work with, there supposed to call me back and let me know about sending me out what i ordered. It should work out either way, just hope to have a couple forges done before our June meeting to sell!!!:) Quote
HWHII Posted May 26, 2011 Posted May 26, 2011 I have only use 1" in all mine and the one's I have made for others. They all seem to work fine. Quote
Francis Trez Cole Posted May 27, 2011 Posted May 27, 2011 I have heard of coating your fiber with this product helps it last longer and retain's more heat.http://www.budgetcastingsupply.com/ITC.php Quote
MattBower Posted May 27, 2011 Posted May 27, 2011 1" works just as well as 2", if you use two layers of it. You should coat your fiber blanket either way, because free ceramic particles are a respiratory hazard. Quote
sfDuck Posted June 11, 2011 Posted June 11, 2011 Yes the 1 in coiled twice around will do the job, but coating using the ITC product designed exactly for this problem does the best job. All forges should have this kind of protection and keeping a jar of this handy in the shop makes sence. Putting piece after piece of metal in the forge is bound to create little scraches and tears ; BUT it also improves the Efficiency. It uses "LESS" propane and any savings you can get is worth it in the long run! Most guys have problems with sagging, No not that! your insulation sagging, its a real problem most men have to deal with. I have seen 1/8 pins welded to the inside chamber of forges and 1 inch squares of metal with a hole in the centre. The insulation is stuck to the pins and the little squares hold it in place. The downside is they burn off in time and have to be replaced. Have Fun Quote
