Bench top press
So im looking at a small 6ton A-frame bench top press from harbor freight. I'm only a hobyist and work primarily on blades and assorted wallhooks for the moment. My shop consist of an 8'x8' shed in my back yard that i added a 4 foot lean to style roof for extra coverage. I was thinking of buying this little press to help with drawing out forge welded billets as they have proven to be pretty hard to push around. The cost of the press is around $65. It has a max verticle working distance of 4" and a horizontal distance between channels of 10-12". This sounds like plenty of room to work with for what i am doing but i was wandering about the tonnage as i havent used a press for this purpose before. Will this little press be able to draw out a 1095 and 15n20 or cable welded billet? Is this practicle or would i be wasting my money? Any suggestions are welcome. Here is the dirrect link to the press if anyone cares to take a look at it. Thanks again!!
http://www.harborfreight.com/garage-shop/shop-presses/6-ton-a-frame-bench-shop-press-1666.html
Hi,
Whilst I don't know that specific press per se', I have found that sort of press is extremely usefull for general assembly and disassembly of mechanical items. That being said I think that for the use that you are proposing you may find it very,very slow and while 6 tons may sound a lot, for forging it is quite light.
My $0.02 worth. :)
Ian
way slow and way light ... there are threads on presses for that type of forging press usually 12/20 ton and air used to speed up press or electric hydraulic pump but you need much more speed that a hand pump can provide..
I do have that exact press and it is very slow. The press plates it comes with are cast iron and both of mine broke in half while doing some simple jobs. It is a handy addition to the shop but I doubt it would be very useful for forging.
Ward
Thanks for the input guys. Guess i'll be sticking with pounding until i cant pound no more as i don't have the room or budget for much bigger. I may be able to pull off a 12ton press in regards to both room and budget but i guess ill have to look into one that is able to be modified to increase speed. If yall have any suggestions on going that route id appreciate it. Guess i'll get to reading more on the subject. Thanks again for the input!
Check out the press that gearhartironwerks has made in
It seems very impressive for one that won't take up much room. It would probably be ideal for you.
Ian
