FieryFurnace Posted April 23, 2011 Share Posted April 23, 2011 So I need a tenon tool for the Kinyon. I'm going to be using the flat dies under the Kinyon and then use the wrap around collar that holds the tool on the flat dies. (I believe it is a Clay Spencer/tire hammer tool.) Anyway, here is what I'm working with. The metal is a plow piece. It isn't the plow point, it is the piece the plow point bolts onto. I'm planning on doing a guillotine tool and a tenon swage per tool. The metal is 5/8"x1 1/2" so I am planning on splitting in half so that each side is 3/4"x5/8". I know about the business card for spacing trick. I'm probably going to do a 3/8" tenon tool first. I am planning on using mild 1/4"x1" FB as the spring and a small piece of angle iron to fit the hammer die clamp. Suggestions or revisions to my plan??? Thoughts??? Thanks! Quote Link to comment Share on other sites More sharing options...
dkunkler Posted April 24, 2011 Share Posted April 24, 2011 Download and save this pdf. http://www.alaforge.org/files/Tire_Hammer_Tools_small.pdf It has the tenon tool and several other cool tools. Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted April 24, 2011 Author Share Posted April 24, 2011 BINGO! Thanks! Quote Link to comment Share on other sites More sharing options...
