teenylittlemetalguy Posted March 27, 2011 Posted March 27, 2011 For a long time now I wanted to try building a set of calipers. I have held a fascination with them for a very long time and they seemed pretty straight forward. I could have used a set of odd leg ones on a project a while back so decided to put them on my list to get. So with this build I killed 2 birds with one stone. Since this was really just to see if I could do it I used mild steel for all but the spring. Purchased a 4" x 1/4-20 machine screw for the adjuster. The posts were 1/2" rod. Turned a 3/8" long section down to 1/4" on the lathe to mount though the leg. A washer and then riveted the head down on the back. over did that a bit so I had to take a while loosening them up. but they work great now. Overall length is 12" as I wanted more range than a tiny set would give me. Typically springs have been a problem for me, but I learned a lot on this build about how to make a spring and am comfortable with the strength and tension in this one. I will build a nicer nut and case harden the tips before I put them away. B) Quote
chichi Posted March 27, 2011 Posted March 27, 2011 Nice job. Look up Peter Ross calipers which have a different function but a real nice project to improve forging skills. Start with the simple 3 leaf and work up to 5 leaf with the tightening screw. chichi Quote
bigfootnampa Posted March 27, 2011 Posted March 27, 2011 It is a very nice looking tool! I agree that you'll want a nicer nut but I can't see the need for case hardening... there should be little wear or pressure on the tool as it's function is only to measure. Nice looking work! Quote
teenylittlemetalguy Posted March 27, 2011 Author Posted March 27, 2011 Peter Ross's work is very nice, thanks for the comments guys. I was thinking of case hardening the tips only, just to protect them as they are small and fragile and I want to maintain a clean line to mark against. my end goal is a pair of cable damascus ones. this was really just to see if I could accomplish the basic form. The spring was my main worry, but now that I know I can handle it I won't be as concerned that I am wasting my time. :) Quote
