tradiuz Posted December 9, 2006 Share Posted December 9, 2006 Hi, my name's Patrick. Don't call me Pat, 'cause that's my father. I stumbled upon this site looking for swage blocks, took a look around, and decided that I had to join. I actually found the swage block I set out to find, just need to save up for it... check it out here. The only problem I see, is that I could probably make something similar for far less, with better materials. I'm not a big fan of cast iron. If it was cast steel, I'd like it a whole lot more. And about cast steel. Harbour Freight, sells a 110 lb cast steel anvil (well they used to, it's discontinued, but in stock) for around $100. Is that a good price? Quote Link to comment Share on other sites More sharing options...
Glenn Posted December 9, 2006 Share Posted December 9, 2006 Welcome to the site. Swage blocks are useful tools when needed. For the one time use, inside or outside curves from many items can be used. See Blueprint BP0184. Seek out a blacksmithing group near you and ask if they know of any anvils that are available. Usually they can point you toward a reasonably priced anvil. Ask everyone you see if they know where you can find an anvil. The item may not be there when you return, so have cash in your pocket. Real anvils are out there and can be purchased, but you have to sometimes look for them. Quote Link to comment Share on other sites More sharing options...
Strine Posted December 9, 2006 Share Posted December 9, 2006 What about Paddy is that alright? What about 'late for dinner'? I hate being called late for dinner Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted December 9, 2006 Share Posted December 9, 2006 try this tradius, they need a little finishing by are much cheaper and are made for blacksmiths not armourers. Saltfork Craftsmen Artist-Blacksmith Association On-Line Trading Place Quote Link to comment Share on other sites More sharing options...
A.S.T. Posted December 11, 2006 Share Posted December 11, 2006 The anvil from harbor freight is not a bad starter anvil or as a back up. A.S.T. Quote Link to comment Share on other sites More sharing options...
