December 25, 201015 yr I love the detail, and the bowl is really awesome. you must have welded it solid and then forged the depression? Now did you end up keeping it or was it a gift for someone lucky?
December 25, 201015 yr Author I love the detail, and the bowl is really awesome. you must have welded it solid and then forged the depression? Now did you end up keeping it or was it a gift for someone lucky? It was piled into a heap and welded just solid enough to handle it, Scrooge kept it. But plenty of others were gifts..........mb
January 1, 201115 yr I love the design, especially the candy shapes. How did you go about making the scroll patterns on the candy? Did you make a scroll from round spring steel and just top fuller it in? Great work Thanks for sharing.
January 2, 201115 yr Author I love the design, especially the candy shapes. How did you go about making the scroll patterns on the candy? Did you make a scroll from round spring steel and just top fuller it in? Great work Thanks for sharing. Right,It was a tight little scroll made of 1/8" welding rod hammered into the metal. I've made other "scrolls" of rebar,allthread,acme thread,whatever. They don't need to be hard steel unless you're in production. All the shapes are pretty ad lib..........mb
January 3, 201115 yr Right,It was a tight little scroll made of 1/8" welding rod hammered into the metal. I've made other "scrolls" of rebar,allthread,acme thread,whatever. They don't need to be hard steel unless you're in production. All the shapes are pretty ad lib..........mb Thanks for the info. "neato" The entire collection is fantastic. It's a credit to you. :)
