December 17, 201015 yr I bought a Peter Wright anvil. Well it has "Wright" stamped on the side. Yet in all the pics I see of Peter Wright they all have a shelf at the front and back of the base. Mine does not. Do I have a Peter Wright? If you look in the pics you can see the base, and where "Wright" is stamped, yet I cannot find the "Peter".
December 17, 201015 yr I bought a Peter Wright anvil. Well it has "Wright" stamped on the side. Yet in all the pics I see of Peter Wright they all have a shelf at the front and back of the base. Mine does not. Do I have a Peter Wright? If you look in the pics you can see the base, and where "Wright" is stamped, yet I cannot find the "Peter". Winston, There was also a Henry Wright about 1890-1914. Look above the Wright for Henry. Also weight mark could be on oppsite side. I had wondered about the lack of flats. Some of henrys had them some not. Ken.
December 17, 201015 yr Author The weight marks are on the other side and are clear. 1.1.17 I have not spent a ton of time seeing if I could find other words. With the Wright so clearly marked I don't see how the other text could be so hard to find. When I get time I am going to clean it up and see what I can find. Thanks for the answers.
December 17, 201015 yr Since it was hand stamped it's very easy to have part of the stamping clear and another part indistinguishable.
