wolfshieldrx Posted November 17, 2010 Share Posted November 17, 2010 Not sure if this belongs in TOOLS or HEAT TREATING, but here goes... A buddy gave me two of these auto body? tools. I reworked one to use as a handled punch. Cut off the flat end, forged down the pointy end, filed everything smooth and air cooled. My question is should this tool be rehardened/tempered or used as is? If I did temper it, oil or water? My best guess would be oil, but??? Also, when I was filing it, it seemed pretty hard just air-cooled. Plus, even if I did temper it, when I use it as a hot punch, won't the hot steel draw the temper anyway? Whattaya think, huh? Thanks in advance...bart Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted November 17, 2010 Share Posted November 17, 2010 are you useing it as a hot punch/ drift? if so hardening it probably would be a waste of time .. also you dont know what alloy it is ... ide leave it as is and use it...btw that was a chipping hammer used for chipping flux off of welds (usually stick welds or flux core wirefeed ) it should work fine for what you want to use it for. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted November 17, 2010 Share Posted November 17, 2010 I think that's a weldor's slag chipping hammer and what you made looks more like a drift than a punch. What did the spark test tell you about the carbon content? I've found that "metal being hard" is a very subjective thing. Quote Link to comment Share on other sites More sharing options...
wolfshieldrx Posted November 17, 2010 Author Share Posted November 17, 2010 Both very good points. I dont weld (outside the forge!) so i learned something. I'm just learning the spark test thing, but appeared to be about the same as auto coil spring. And yes, meant to say drift. Thanks a bunch...bart Quote Link to comment Share on other sites More sharing options...
