Smoke Hood for Outdoor Forge
Hi All,
I have a homemade outdoor forge that sits inside a lean-to type shed to keep it out of the rain. The problem is that because of the roof on the thing, I spend a great deal of time with my head in the smoke.
I'm looking for any suggestions for:
1. What type of hood to build? I'm leaning toward a side draft such as the super sucker or a half hood rather than an overhead hood.
2. Type of Chimney pipe for this application? Do I need double or triple wall flue pipe to keep from burning down the roof, or is single wall pipe sufficient? (I'm thinking straight up through the roof would be best, since there is very little clearance between the roof & the fence on the left or back sides.)
3. Suggestions for where to purchase 10" to 12" flue pipe of the suggested type? I haven't seen any at the local Lowes or Home Depot.
4. From what I read in other posts, 10' height seems to be the magic number, along with 4" above the peak of the roof. Which do I go with, and does the 4" rule apply in this type of application?
Here is a picture of the forge. Any suggestions would be appreciated. I'm starting to get information overload from trying to research this stuff, and somehow I don't think it needs to be as complicated as it seems.
Thanks,
- Jim
post-14464-073110200 1288202652_thumb.jp
Super sucker looks like it would work well for your shop. It is small, uses little metal, and from the pics I've seen it looks like it works well.
Don't know if you've seen my thread, but I just purchased 12 inch smooth sided rigid heating duct. Just contact a heating and air supply. I used 5 foot sections, of 24 gauge and it cost me $20.00 a section.
I can't speak with authority on going through the roof, but I would think you will need some sort of double or triple wall piping for that, just because it looks like your fire is going to be pretty close to your roof.
Hope that helps!
Hope that helps!
Dave,
I guess your suggestion about the double or triple wall pipe makes sense based on the amount of heat passing through the chimney at that point. The heat isn't a problem as it is now, but maybe the metal flue pipe will transfer what heat there is to the roof. I guess I was hoping for a way to not have to spend several hundred dollars to protect a 50 dollar roof. Thanks for your input.
- Jim
This is what I used,just some steel off an old appliance.
http://www.farwestforge.com/Forum/bsgview.php?photo=1463&cat=&by=Sweany
yes it works
http://www.farwestforge.com/Forum/bsgview.php?photo=1464&cat=&by=Sweany
Sweany,
I like the way you were able to work with what you had at your disposal to redirect the smoke form your forge. Ingenuity and creativity is one of the things that attracted me to blacksmithing in the first place. I'm thinking about how I might be able to use the way you've connectd your chimney to the forge. What puzzles me though is, if I were to model the base of my chimney after your example, it appears that I would still have the problem of smoke collecting under my roof and blowing back out in my face. Have you ever considered how to connect a flue to your chimney to increase the draft and direct the smoke higher? I'm also wondering if maybe there might be a way to create enough draft to be able to redirect the flue around my roof rather than having to cut a hole through it.
Thanks,
- Jim
I never got around to attaching a chimney, I usually roll the forge outside in good weather.
My forge shop has a full vented gable roof. I have doors on 4 sides of the shop, to help regulate draft and sunlight etc.
A little breeze and all the smoke goes up.
Dave,
- Jim
Yea I know what you are talking about! I don't even know where you would get 10-12 inch double or triple wall pipe!
Just a suggestion, turn your forge so the hood is next to the opening, stand your chimney on the ground outside the opening and run a short horizontal to the chiney.
No triple wall needed.
You can get triple wall or inulated pipe at a wood burning stove store. In your case all you would really need is the thimble....
Hey Guys, Thanks for your input. I thought about turning the forge as suggested, but it weighs close to 300 pounds with the firebrick, and the part where the firepot is would end up outside the overhang. (I don't want rain mixing with the ashes then dissolving the bottom of the pot.) Looks like I'm on a quest for a thimble - great idea! I'll post a picture when I get the chimney installed, hopefully before it gets to cold.
BTW - I found out that triple walled flue pipe is no longer avaialble in my area because it doesn't meet code anymore. Apparrently, triple walled pipe is air-cooled, and doesn't contain any refractory insulation like the UL listed double wall.
Thanks again
- Jim
