Fosterob Posted August 1, 2010 Share Posted August 1, 2010 Here are a few pics of a simple bending jig I copied from a local shop. They called it their "secret weapon". It is a 3/8" thick plate 7 1/2" x 14 1/2" and the curves are 1/2" x 1 1/2" bar. the curved pieces are curved differently in each quadrant. #4 is the sharpest and #1 is the shallowest. 2 1/4" between curves at the narrowest point. It is great for bending a few parts. I can put stops in the table to get repeatable bends. Also I have a mount for it that plugs into the trailer hitch on the back of the truck for making simple adjustments to things in the field. There are a few pics of some bends I have done with it. The long peice is 18' and made of 3/4" solid square with the 1 3/4" molded cap rail and the gate is 1" tube frame. Pipe rail is 1 1/4" sch 40 and was done all done on site. The guys I copied it from used it to bend the 2 1/2 " molded cap rail the hard way and I have bent 1/4" x 2" flat bar the hard way. Works good for shallow bends on pipe also. All cold bends, with heat you could just about bend anything you could fit in it. It is also useful to straighten forged pieces. Rob Quote Link to comment Share on other sites More sharing options...
monstermetal Posted August 1, 2010 Share Posted August 1, 2010 Great jig! I like the 4 platen tables all in a row too.... I always thought the ultimate work area would be 4 platens arranged in a square with about 2 feet between them making a 12' square... Quote Link to comment Share on other sites More sharing options...
David Browne Posted August 1, 2010 Share Posted August 1, 2010 Funny, how so many times the simplest jig or tool is more often than not, the first one that you reach for. 4 platens in a row...soooooo jealous. -DB Quote Link to comment Share on other sites More sharing options...
Naz Posted August 1, 2010 Share Posted August 1, 2010 This one's going on my "to do " list ! Simple and very functionnal. Thanks for posting this. Naz Quote Link to comment Share on other sites More sharing options...
youngdylan Posted August 1, 2010 Share Posted August 1, 2010 four ....... he's got four the lucky xxxxxxxxxx Quote Link to comment Share on other sites More sharing options...
double_edge2 Posted August 2, 2010 Share Posted August 2, 2010 four ....... he's got four the lucky xxxxxxxxxx someone distract him and we'll run off withem Quote Link to comment Share on other sites More sharing options...
CurlyGeorge Posted August 5, 2010 Share Posted August 5, 2010 Cool idea on that jig. Thanks for the dimensions. That will come in handy. :D Quote Link to comment Share on other sites More sharing options...
eric sprado Posted August 5, 2010 Share Posted August 5, 2010 I'm sorry: I just can't figure out how jig is used.. Is it clamped to platen? I guess that's why I don't make a living blacksmithing. Quote Link to comment Share on other sites More sharing options...
Fosterob Posted August 5, 2010 Author Share Posted August 5, 2010 Yes I have it pegged into one of the holes on the platen table shown. It can be attached to a bench or anything sturdy that will not move easily. I use it on a peg that goes in the trailer hitch of my truck for field work. To use it you just put your metal piece in between the two curves and pull it. It will not work on short pieces, depending on the material 2-3 feet would probably be the shortest. You can always bend a long piece on the end and cut it. Depending on which quadrant you pull the metal around is how you get a different radius bend. If you need a tighter bend use #4 in the pic or a more gradual use #1 or #2. I have only use it cold but no reason to not use with short pieces of hot metal and bending forks. Hope this clears things up, thanks for the interest in it. Rob Quote Link to comment Share on other sites More sharing options...
Darius Posted October 2, 2017 Share Posted October 2, 2017 Hey does anyone have any links to these pics i dont see any Quote Link to comment Share on other sites More sharing options...
