Corrigan Posted July 21, 2010 Share Posted July 21, 2010 Hello all, I need a plasma cutter for a job I have coming up ( 200 shapes cut out of thin sheet, 1.3 to 3 mm ) Ive been looking on the web and found RTech welding. They have an inverter for a really resonable price £410 that claims a clean cut up to 8mm. As they are quite a bit below other makes price wise I was wondering if anyone had used one and were they any good. Should I lay out more cash , I I'd probably get a fair bit of use from it but moneys a bit tight ????? Link to comment Share on other sites More sharing options...
Zsartell Posted July 21, 2010 Share Posted July 21, 2010 I've never owned a plasma cutter, but I have used a few different brands. The nice ones (hypertherm) cut pretty decent and the cheapo's cut so bad I would have rather used an oxy/acetylene torch. That doesn't mean that there aren't less expensive plasma cutters out there that can't do the job, just not the couple that I have used. Link to comment Share on other sites More sharing options...
Philip Borde Posted July 21, 2010 Share Posted July 21, 2010 One thing to consider is the price of consumables, some off brands cut good but are pricey when buying consumables.I have a thermal dynamics pak15 also a plasma made by Harris shortly after I bought the harris they sold out and quit making the comsumables for it, I did find an older welding shop in the houston area that had a bunch of parts so I bought them all. The thing I dont like about the Harris is the focus ring is made out of ceramic and breaks easy. Point is check out the consumables pricing and availability for the unit you want to buy. Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 21, 2010 Share Posted July 21, 2010 May be much better to buy a name brand used than an off brand brand new! On this side of the Atlantic both brands mentioned above are well thought of. I've never heard of the RTech. Link to comment Share on other sites More sharing options...
Corrigan Posted July 22, 2010 Author Share Posted July 22, 2010 Ok , thanks guys will look into second hand ones and consumables, Cheers ! Link to comment Share on other sites More sharing options...
Please sign in to comment
