Jim L. Posted June 8, 2010 Share Posted June 8, 2010 I was wondering if any one had ever used brake disks to forge a blade from. I'm told that these are made froma very high carbon steal (I'm thinking motorcycle disks). My thinking is that they are exceptionally hard and after working can be configured via forging, treat and quenching might make an interesting blade.....or would this be a waste of time. Jim L. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted June 8, 2010 Share Posted June 8, 2010 You may want to contact one of the manufactures to see what they make their brake discs from. In any case take a piece, heat it quench it, and test for hardness before making a knife. Let us know what you find out. Quote Link to comment Share on other sites More sharing options...
oldwing Posted June 9, 2010 Share Posted June 9, 2010 I agree you should check with the manufacturer or at the very least the shop manual. I have an old Goldwing, and the rotors for it are stainless and very hard. Quote Link to comment Share on other sites More sharing options...
Jim L. Posted June 11, 2010 Author Share Posted June 11, 2010 Will do! This won't be a fast project, but I'll keep y'all posted. Jim L. Quote Link to comment Share on other sites More sharing options...
reefera4m Posted June 15, 2010 Share Posted June 15, 2010 Brake discs are largely cast iron ( only 3% - 4% carbon), though some have ceramic or carbon fiber included. Probably not the best choice for forgin a knife and probably not much better than a RR spike (2% carbon). Quote Link to comment Share on other sites More sharing options...
pkrankow Posted June 15, 2010 Share Posted June 15, 2010 Brake discs are largely cast iron ( only 3% - 4% carbon), though some have ceramic or carbon fiber included. Probably not the best choice for forgin a knife and probably not much better than a RR spike (2% carbon). I thought RR spikes had about 0.2% carbon, quite far from cast iron. Automobile disks tend to be cast iron, but some performance versions are cast alloy steel. Phil Quote Link to comment Share on other sites More sharing options...
nthe10ring Posted June 18, 2010 Share Posted June 18, 2010 Steel is cheap, if your going to put the effort into a knife, buy some of the 10 series steel,,,1084 is good and you will know what it is and can work on a good heat treat. For 20 bucks you can buy enough to make a dozen fairly large knives or 20 small ones. When your finished you know what you have. Jerry Quote Link to comment Share on other sites More sharing options...
