September 2006
Glenn
There are a lot of double disc rotors being replaced in this area. Let's do something a bit different this month and make something useful using this item.
The discs I have seen have different patterns of bolt holes, 4, 5, 8 so you get your choice. The webbing between the discs seems to beg to be used in some way. Use your imagination.
Great idea, but only if they are single side discs. The double sided discs have the air holes between the discs. This may effect the fire, I am not sure as I have not tried the double disc rotors in that application.
I have built 2 forges using the single sided discs and they both work well. Great suggestion.
  • 1 month later...
