February 20, 201016 yr Wow,the wood rack only holds one log......makes for a quick fire. Just kidding .. good looking work you have there. I like the handles on your tools.
February 20, 201016 yr Wow! That is amazing! I really like them. I can't imagine how long it must have taken to draw out the squiggly parts on the rack (forgive the technical terms ). Hogan Baker
February 20, 201016 yr Author The only complaint about the wood rack is that it keeps needing to be refilled . "Squiggly parts" is in fact the correct technical term, they don't take too long when you step on the treadle and the power hammer goes "THUMP THUMP THUMP THUMP THUMP...." Thanks
February 20, 201016 yr I can see how a power hammer would make the work just a little bit easier . Even so, great job! It is really impressive how you made the seemingly random squiggles almost mirror images of each other. Hogan Baker
February 20, 201016 yr very nice work. what do you do for the broom? is that a component you buy and attach?
February 21, 201016 yr Author Mills- IIRC that broom I got from Blacksmith's Depot, it's bristles into wood and you can either thread the end of your tool and pass thru the wood and screw on a nut or TIG weld on a lag screw. There used to be a guy around here that would tie better looking brooms onto your handle, but he retired.
