Ironic Posted December 4, 2009 Share Posted December 4, 2009 I've been trying to make ornamental baskets from 'wrought' iron (ie mild steel) using 6mm square rod cut into 4 even lengths then end welded. I have an Eisenkraft MT hand operated twisting & basket making machine. Problem I have is that to get the required shape I seem to end up with excessive twisting at the ends of the basket which causes the rods to snap. Any tips hugely appreciated. Quote Link to comment Share on other sites More sharing options...
thingmaker3 Posted December 4, 2009 Share Posted December 4, 2009 Try either localizing your heat to the middle or cooling the ends. Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted December 4, 2009 Share Posted December 4, 2009 More weld area on the ends - you need at least 12mm or more of solid weld on all rods. Quote Link to comment Share on other sites More sharing options...
matt87 Posted December 5, 2009 Share Posted December 5, 2009 How are you welding the ends? Quote Link to comment Share on other sites More sharing options...
arftist Posted December 5, 2009 Share Posted December 5, 2009 This has come up on other forums. The only way I have ever made baskets is by cutting and splitting. Didn't know there was a machine available, not surprised though. When using the machine is the twisting and bending done cold? When forming by hand, both the heat and when the basket is pushed back on itself determine the final shape. Did the machine come with instructions? Quote Link to comment Share on other sites More sharing options...
