BadKarma Posted September 16, 2009 Share Posted September 16, 2009 I am in the planning stage of building my first forge and have a question: What's the difference between Kaowool and Durablanket? Why would I choose one over the other? So far I'm trying to choose between a steel paint bucket or a freon bottle for the shell. Thanks. Karma Quote Link to comment Share on other sites More sharing options...
pkrankow Posted September 16, 2009 Share Posted September 16, 2009 Brand is the big difference. There are some small differences if you carefully read the msds for each product. If you are selecting similar temperature ratings, thickness, and density they are equivalent to each other. Phil Quote Link to comment Share on other sites More sharing options...
BadKarma Posted September 16, 2009 Author Share Posted September 16, 2009 Thanks Phil. Quote Link to comment Share on other sites More sharing options...
Frosty Posted September 16, 2009 Share Posted September 16, 2009 Like Phil says brand is the main difference. Applying a stabilizer, rigidizer, etc. is a good idea. It makes the blanket tougher and encapsulates the fibers which can be a lung hazard. You might consider using single wall stove pipe for the forge shell. It's commonly available, easily worked, requires no special tools and can be made any diameter you want by snapping different diameters together at the seam. Frosty Quote Link to comment Share on other sites More sharing options...
