Avadon Posted August 24, 2009 Share Posted August 24, 2009 (edited) I have a special-cut firebrick for my gas forge but when I was futzing with some doors i'm welding on it came down and broke the small brick. They are fragile/brittle when thin. Anyway, can I glue it back together or is it just funeral time.... :confused: Edited August 24, 2009 by Avadon Quote Link to comment Share on other sites More sharing options...
Ratel10mm Posted August 24, 2009 Share Posted August 24, 2009 I glued my one-brick forge back together the other day, using cement I got from my brick supplier and so far it's holding together. :) Quote Link to comment Share on other sites More sharing options...
pkrankow Posted August 24, 2009 Share Posted August 24, 2009 (edited) If the pieces stay in place, no need to glue. Small cracks are "normal" and should not affect operation as long as the crack is held closed. If you have a gap you may have a problem. You can also coat over the crack with your stabilizer or reflector (plistex, itc, kaolin, etc.) if you are worried about it. Phil Edited August 24, 2009 by pkrankow etc. Quote Link to comment Share on other sites More sharing options...
Marc Posted August 27, 2009 Share Posted August 27, 2009 You should be able to get some furnace cement from the big box stores and small hardware places. It'll get glassy at forge temperatures, but still holds bricks together. Quote Link to comment Share on other sites More sharing options...
welder19 Posted August 27, 2009 Share Posted August 27, 2009 They make stuff that comes in small squeeze tubes for sealing castiron woodstoves and glueing in door gaskets and such get a tube of that to glue it back together, if it really needs to be glued that is. welder19 Quote Link to comment Share on other sites More sharing options...
